Quick question with hopefully an easy answer. I swapped axles this past weekend and the new axle has drum brakes (as did the old). I bled the brakes when I was done and the brakes work fine, except that there is a rubbing coming from the back passenger side rear that sounds like what disc brakes sound like when the pads are gone and metal rubs on rotor. It rubs about 75% of the time and continues even while braking. I know nothing about drum brakes, but I had to take off the front plate that shows the brake in order to get to the emergency brake and I'm pretty sure it's not the e-brake as it is set according to the book and works well. Any suggestions on what the problem is and what I can do to fix it? Thanks, Scott
