- Sep 20, 2018
- 353
'74 , stock 302 with hydroboost front disc/ rear drum setup.
I recently had the Wild Horses front disc brake conversion kit installed in March. Have not had any problems...... until yesterday when I changed out the rear drum cylinders. Everything went back together smooth. When I bleed the back pumping a couple times very little came out but when I check the reservoir it was empty. Obviously added more fluid, continued to bleed the entire system several times but still when I turn her on the pedal goes to the floor. Tried bleeding more, minimal amount of fluid coming out.
Am I missing something? Are you supposed to bleed the system with the vehicle on with hydroboost?
I double checked the rear drums adjustment and those were good.
Thank you in advance for your time/help,
Sonny
Sonny
