Just to give you an idea, it's going to look something like this but because I only have a 1 inch body lift instead of the 2 inch on this vehicle, mine hangs down lower. I can rotate the 6 port switch to horizontal and put it on top of the cross member (there's enough room) to get it out of the way, but the pump hangs down. Wouldn't mind putting it on the frame except it would have to shift forward because of the triangle bracket which holds the rear brake line. I can even move it off center to the driver's side to help clear. Would prefer to have it on the cross member unless I can't. Maybe directly under the cross member. That's past where the pumpkin is.
