Rear seat bracket/storage box help needed
DJM75
Washougal
Ok so I bought a rear seat out of a suzuki sidekick/ Geo tracker and I don't have the bracket and stuff to install it. So what I need is somebody to build me the bracket/ storage area. And yes I would pay them. So if there is somebody in the NorthEast willing to take on this project for me I greatly appreciate it. I've drawn up some plans. and I'll post them. Sorry they aren't pretty but it's been awhile since drafting class and paint isn't the best for plans. Basically it's a box with 4 of the sides enclosed (top, sides, and front) with places for me to bolt the seat too and bolt the box to the floor. Sorry if this is the wrong place to post this. Please move it if it is.
Don
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
I could make that. 1/8th steel ? Give this guy a call and find out what the steel will cost. He sells everything , steel, aluminum, tubing, etc. He will even cut it to size for you so all you have to do is have it bent and welded.
Keith - Metal Supermarkets 518-436-0024
He is on Railroad Ave , behind where Northway Mall used to be.
D
DJM75
Washougal
Do you think the whole things needs to be 1/8 steel? I was thinking maybe a steel frame and aluminum sides to save some weight. But if that would cost too much then I'd be willing to go all steel. What do you suggest? I just want the box for some underseat storage so it's easily changed if necessary. The mounting holes need to be where they are but I'm sure you already knew that. Oh yeah when I measured all this I forgot to take the passengers into consideration. So the box length needs to go from 36" to 28" and the holes to mount it to the floor need to be changed accordingly too. Not that it's important right now.
Thanks for the help.
Don
67ster
I made something similar for my Amigo rear seat . I had some channels sheared and bent from 14Ga. mild steel and have floor brackets made from 2x2x 1/8, these are bolted to the factory holes . It seems stout enough and when you consider that most are bolted into 18-20 ga. sheetmetal to start with.
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
You can make your box out of anything you want. I do not have the welding aluminum to steel thing yet ;) but I guess large rivets would work. I say 1/8th because if someone heavy rides back there, you probably don't want it to crush. I also have a friend who welds aluminum if you would like a box made out of aluminum or diamond plate aluminum. If you want you could give him a call Rich - 518-372-2252 He is a teacher at Modern Welding if you want to try him there.
