rear seat bracket
Ropagnani
Just looking for some direction on this, i am working on putting in a new family style roll cage, as i was clearing things out I went to take out my rear seat and found it to be only held down to the flooring by 2 bolts and a nut!, scares me a bit, is there a bracket to install or some other ideas to get this maybe bolted into the frame properly to make sure it is at least a little bit more safe for the kiddos riding in the back? any info is greatly appreciated
thegreatjustino
Red Head Grease Monkey
Stockton, CA
From the factory the rear seat bolted to the floor with four bolts. There were four nuts welded to the bottom of the rear floor pan to bolt the seat to.
jckkys
It sounds like Frankenbronco is an apt description. I don't know of any vehicle that has the seats mounted to the frame. Maybe that's an indication it's a bad idea. It also sounds like you need a real shop manual to learn how your truck was designed.
blubuckaroo
Grease Monkey
Ridgefield WA
I've even seen the seat belts bolted to the back of the seat. Now that's scary. It certainly couldn't have been factory.
That would put quite a strain on the little 5/16" bolts that hold the seat to the floor.
BTW, the seats on these cars weren't vert substantial anyway. I was shocked to see how cheesy the frames are in the buckets. I ended up doing weld repairs on my driver's seat twice before I replaced them with something good.
Rustytruck
the seats and passengers are restrained to the truck by the high tensile seat belt bolts and seat belt webbing. its a package deal. want to worry about something, the low seat backs are the danger as is anyone's head near a roll cage. especially problematic right over the rear seat. My ex wife took a header into the padded roll cage over head bar the head was fine but she chipped a front tooth. at least that's the story and I am sticking to it. the worry isnt the 4- 5/16 mounting bolts or the 4- 1/2-20 seat belt bolts. Anything could be built better but back in the day the world didn't make excuses to control everyone. but cars now cost almost 10 times the cost back then but are a whole lot safer.
