Rear Seat Options
Yooper74
Looking for a rear bench for my 74. I've got mustang seats from a 2007 in the front. would like something that kind of matches that. poked around at all the vendor and have seen a few that might work.
thought i'd throw it out to the group see what I'm not aware of that's out there.
Ratclge
Back seat
I got a jeep rear seat for 90s to early 2000 models that works really well,they are the same width as old broncos. Mine is a 75 bronco. Besttop makes them. I could send a pic if u want.
Bajabrewer
I scored a 2 person seat(they also come in 3 person - too wide) from a Ford Transit van for $20 & figured it was worth a shot. The base is really tall so I cut that off & built an angle iron bracket that bolts right thru the floor. If you wanted you could probably use the existing seat mounting bolts but I have a speaker box that got in the way of that so I made new holes. I like the high back with headrests but it does get in the way looking in the rear view mirror. They tilt a little & don't fold flat which is a drag but overall for a cheap custom seat with built in 3 point belts I'm ok with it. No backseat passengers on the dunes for me so I'll pull it out when I go play in the sand.
