Rear shackle
gmduncan
Annapolis
I think I know the answer. I removed the inner shackle bolt sleeve and rubber bushing.
First picture shows the inner metal sleeve and the other metal sleeve. The second picture shows the inner metal sleeve removed from the shackle and an arrow pointing to what I think is another metal sleeve that needs to be removed. The third picture is the new bushings next to the shackle. The fourth picture the new bushing on top of the shackle and the other metal sleeve. They appear to be the same size and without removing the other metal sleeve, the new bushing will not fit.
It looks like there's another metal sleeve that needs to be removed before I'm able install new bushing and metal sleeve. Can anyone verify that fore me please....?
Thank you.
EPB72
Pleasant Hill, CA
Yes to install polyurethane bushings the outer sleeve needs to be removed.. as it would also need to be removed if installing stock style as well…
papy
just did (tried) this on my 79 bronco. the inner sleeve was so rusty it wouldn't come out - tried everything. I ended up buying new shackles for less than the cost of the replacement bushings.
