Rebuild 170 I6
chrlsful
tuning, machining, specs (144 - 300 ci)
Go for it. The machining is the hard part. Most of the assembly is easy. Just find the right torque specs and sequences for the crank, rods, head, and manifolds. Lube everything well for I itial startup.
All on the CI site.
bmbm
I can understand the originality thing, I still have my 170 in the garage. I drove my bronco with that worn out 170 for about 10 years and always enjoyed it. It's just one of the coolest vehicles you can drive.
chrlsful
How much off roading is done?
Thanks,
chrlsful
ahhhahah!, we're 'opposites'
8-0
Tell U what, tho - I'd rather have ur off rd locale than mine!
;D
I should deffinatly ask:
how's the low gear in the NV on the gradients? (& 'slipperies')
You know if an RBS carb will B fuel starved in such cases?
bmbm
For this environment the first gear works very well. For steep uphill on the roads with small loose rocks, sand and dirt I go into low range and just enjoy the low end torque.
Never had fuel starvation yet but no steep side hills really.
chrlsful
OK, that helps.
"…into low range…" Ahh, only need the transfer then. Wouldn't get it here too steep.
"...Never had fuel starvation yet but no steep side hills really."
OK, just askin bout ur knowledge on an RBS.
C U here or the odder place!
