Recommendations
Chief Master Sergeant
Retired U.S. Air Force
I am deploying next week for six months and want to be sure I store the Bronco properly. It will be in my garage, out of the elements, but I just got it running right and want to be sure it will be close to the same when I return. I intend to put it up on jack stands to get the tires off the floor and disconnect the battery. Do I need to worry about treating the gas for that amount of time? Should I remove the battery or just disconnect it? Am I forgetting anything?
Chuck
ugly74
Bronco abuser
Colorado
add some Stabil to the fuel, it'll be fine.
are rodents a problem? if I let something sit for even a few days, rodents invade, and birds build nests%)
Kyle.malone
Norman, OK
Stabil for sure. Disconnect battery. If there is no top on it, I would not cover it as it is easier for rodents to hide in. I have always left mine uncovered in a barn without a rodent problem due to the fact there is no where for them to hide. Plus having my brother-in-laws pit bull around helps out too.
W650Mike
Eastland, Texas
Moth balls in a coffee can with a few small holes poked in the top will keep the mice and bugs away without stinking up the entire shop.
Marine stores sell an engine fogging spray for long term protection of internals.
Staybil in a tank filled with premium; drain the carb.
Disconnect battery and put it on a trickle charger.
Good luck and THANK YOU for your service.
cmatthews7
Lake Placid
X2 on the mothballs. I also like the idea of draining the carb, and I will add either the Stabil or fill the tank up full with Aviation fuel and add a quart or so of Marvel Mystery oil when I do that. Av gas will go bad also, just usually takes a lot longer than pump gas.
broncnaz
Definetly want some stabil in the tank for your area. Disconnecting the battery is probably a good idea but if you dont have any electronics that draw off the battery when the ignition is off then I really wouldnt worry much about it. Jacking it up is not really nessesary with todays tires. it was the old bias ply tires that would get flat spots from stting in one place but I guess it doesnt hurt.
I've never done anything to my bronco when I've deployed did several 6-8 monthers and the bronco fired right up every time even after sitting all that time. Cant say the same thing for my 03 ranger as the last time the battery was totally drained when I came back I think the alarm system did it.
Skiddy
i have let mine sit for almost a year and didn't do anything to it, probalbly shoud had put stabil in it i could smell old gas after i started it up, but did have mice in it, dryer sheets also work which is what i will be doing this winter and may try the moth ball thing
sandguy356
Holland, MI
Since it gets cold here and there, just remember to add a little anti freeze to your coolant, some fresh straight up, not 50/50 mix. I also like the idea of pulling the plugs and a little shot of marvel mystery oil to protect the cylinder walls while its sitting. I like putting mine on jack stands too, if for no other reason than its easier to see if anything leaked when you get back.
Thanks in advance for your service.
eds66bronco
Essex, Vermont
we used to have really bad mouse problems with our camper until we started covering everything with dryer sheets and have had no mice after that. Make sure to put a couple in the glove box and i usually will cover the air box, vent box and plug the tailpipe (just remember to unplug it before you start it up again... don't ask). Thanks for your service and be safe!
nelson_bros
los anchorage
Chuck,
You could always just drive it down to Homer and drop it onto the ferry to Kodiak and i will make sure the gas gets cycled and the tires stay round for ya!!;D
thanks for continuing to serve, i hope you have a good deployment.
jarrod
