74bronk
- Sep 1, 2004
- 358
Ok, just received bronco back from paint shop I want to start putting the doors back together. currently the window are still inside the door but removed from track. door to lock knob is still there the door latch still installed and the inside door handle. i bought new door handles for outside, door locks w/keys. looking for advice on installing everything....thinking the door latch i might remove it and replace it completely with everything else because it seems when you close the door now you have to push the lock down for it to catch otherwise you can just push on the door and it will open. thinking at this point replace all with new.......which brings me to one last thing is it possible to remove old glass and put new glass in with out having to cut the top frame of door off? and what about removing the vent glass window also?
any advice or insight or step by step instruction on how to reassemble the door would be very helpful!
T.D.
T.D.
