Distributor reinstalling question
FORD*DIEHARD
So while trying to reinstall the distributor having a tough time having it (seat). Looking down into the (port-probable not the right terminology) there looks like a (6 sided pin) that goes into the middle of the distributor. The (6 sided pin) appears loose and doesn't want to go into the distributor. Is this(6 sided pin) supposed to move at all or should it be "fixed" and he distributor should just fall right in?
Thank you in advance for your time/help,
Sonny
bronco italiano
That is the oil pump drive hex. They make a tool that you can place down there and turn it slightly so the distributor will seat with less problems. I advise against using a socket on an extension. O'reilly's has free tool rentals.
Brush Hog
NorCal
I used a nut driver to turn mine. Actually used it on a power drill to make sure oil pump worked and things got lubed up. Then pulled that shaft out greased up the end so it would stick in dist shafter without falling out and stabbed dist and oil shaft as one piece. Getting dist to line up with that shaft while it’s in the engine was impossible.
m_m70
Prescott AZ
I usually just get the dizzy down as far as it will go and bump the starter (with remote, keeping downward pressure on distributor ) and the distributor falls in place. By the time you have it down to where it hits the oil pump shaft, its already engaged with the cam gears. As long as you keep pressure on it while bumping starter, it'll stay in phase.
FORD*DIEHARD
FORD*DIEHARD
So I was able to turn it with a socket and it seated.
Now I just have to wait until tomorrow to be able to put in the radiator fluid.
I just hope everything lines up right and she fires right up........ what are the chances of this happening?
Thank you everyone for your replies/help!
Sonny
Slim to none… Or just fine, depending on your luck.
Getting it right back to exact timing just by dropping it in happens, but timing is way off as often as not.
You need a timing light to verify, or at least be able to tune it by ear, or a vacuum gauge.
Obviously the engine had been moved slightly, or the original distributor would have just dropped right back in.
Has something been replaced, or worked on while the distributor was out?
73azbronco
Sonny
Hope, is not a strategy, Obiwan. Sounds like you did it right, so i say, it will work 99%.
Are the spark plug wires in the right order though...
thegreatjustino
Red Head Grease Monkey
Stockton, CA
If assembled correctly, the shaft would have a keeper on it that prevents it from pulling out. Done correctly, the shaft stays with the oil pump and the distributor is installed as the OP is doing.
FORD*DIEHARD
FORD*DIEHARD
*UPDATE- Well , for those that know me (If it wasn't for bad luck I would have No luck), I was nervous, with all the new parts installed without. Being able to test after each installation, but last night we buttoned everything up and fired her up and she ran. Minor tweaks and she stayed running. Right now she seems like she is shifting hard at a high idle. Researching this issue the cause points (possibly) to the vaccum modulator. Haven't got that far yet to see which one I have ( I have discovered there are multiple different vaccum modulators with different strip colors).
Next step, is the ""Funnest " that I am sure we ALL ENJOY, finding a store that has the one you need.
Let the searching begin,
I will update again.
Sonny
m_m70
Prescott AZ
Do you mean shifting hard at high RPM's or going into gear hard at high idle??
In my experience, Bronco c4's have always shifted a little harder than the passenger cars did.
Was there a shift kit added at some point?? That would make the shifts even more "firm". Not sure if you're familiar with the tranny and what's gone into it over the years.
