remove bolts from door post
john t
What is the best way to romove the bolts from the door post, if they are rusted in. drill them out one by one or? anybody got any good ideas.
broncomaster
Edgewood,Wa
I have heated each one then slightly tighten first. Follow with more heat then back them out only had one break on the bronco I did this on.
brian72
Early Bronco Student
they make a tool that has a phillips screwdriver head on it and a striking plate on the rear. Hit it with the hammer and the tool applies pressure and turns the driver head. That might work on your stubborn bolts. Don't forget to use PB Blaster on it a couple times and let it sit and soak.
NMWILLY
Hendersonville, NC
I just went through this. The options above are your best route, until you strip out the screw. If that happens, drill the screw with a drill diameter the same or just smaller than the threads. Drill just until the countersunk head comes off. Once you do all three (if you have to) The hinge will come off and usually you can grab the remaining screw with some vice grips and turn them out. If they still wont come out then it's more drilling and try not to mess up the threads in the backing plate. If worse comes to worse you can always install a helicoil in the backing plate but if it's gone this far you will probably start thinking of selling the bronco, getting drunk or converting it to a roadster.
Good luck.
chipreibel
Long Beach
When I removed my hinges, I welded the inside of a nut (where the threads are) to the head of the bolt and used a socket to turn them out. I had to use more heat than I thought I would, but it worked like a champ - no broken bolts. I am sure that the heat from the welding helped to break them loose as well...
BamaBronc
Alabama
I wish you would have told me that before I had to go to church and repent for all the swearing I've done.
Madgyver
Bronco Madman
I've done this to many broncos that I've come across.
Weld a 3/8" nut to the head of the bolt, squirt some oil on it while it's still hot, and then back it off with an impact wrench..
Easy, It works all the time.
There is a thread on this where I posted pics, Try and run a search....
eds66bronco
Essex, Vermont
that's the only way to remove anything up here in the rust belt.
cgbexec
Naples, FL
I squirted mine with penetrating oil and let it sit overnight. The next morning, they still would not budge. I then when and bought an impact screwdriver like mentioned above (you hit it with a hammer and it applied pressure and turns at the same time). I gave them one wrap tightening them and a wrap in the looseing direction and everyone of them came out without a fight. If you don't have a welder, that would be my suggestion. Drilling them out is going to be a lot more mork and in the end you will end up breaking off bits and makign things worse.
