Lasagna King
- Mar 19, 2018
- 1
I finally have the time to work on my 72 sport. I want to do a full restore and cut out all the rust. I’ve done a lot of commercial welding and I am profecient in Tig and spot weld gouging with a hypertherm powermax 65. I’m going to cut out both front floorpans because they previously were repaired with non groove steel plates. I am go to remove the floor shifter and reinstall the 3 on tree. Replace the trans floor cover that was cut out for the floor shifter. My back bed has a 16in by 16in section that needs to be cut out. I can afford to get to buy the complete Dynacorn floorpan front and back but I want to remove the floor and salvage as much of the floor I can. Am I better off replacing the complete floor with a new Dynacorn floor or should I keep as much of the original steel.
