Im starting on a new body lift but even after videos and many searches here, I'm still a little unclear on the removal process.
So far all the bolts, minus one that sheared off, have come out. So once I lift the body (after separating or loosening steering column, clutch linkage, filler lines, etc) will the mounts come out or may I still need to cut them in some way? I will likely figure it out once I jack the body up, but that won't be for a few weeks and I'm trying to prep my head for what's coming.
I was prepared to Sawzall them and burn rubber as described in most write ups, but the bolts have all come up. Did I just get lucky or is cutting and prying still likely in my future?
Thanks as always
Thanks as always
