the-glove
I'm going to be putting in new lower intake, upper intake, and valve cover gaskets. Because I'm removing the lower intake, I need to take out the dizzy. From surfing around for information on how to do this, most posts I've seen say to mark the rotor location on the lip of the distributor and also mark the shaft where it goes into the block so it all goes back in without messing with your timing. A lot of posts also say that you should find TDC of the #1 cylinder on compression stroke before doing all this. I'm trying to understand why you need to do this if you're already marking the rotor location and the distributor body location. Aren't those two marks what helps you get it back in correctly? What does having crankshaft at TDC do? Is it just another way to check it's going back in correctly because you're looking to see that the rotor is pointing at the #1 lead? But isn't that just the same as making a mark on the lip and aiming the rotor for that mark when putting back in? Can I just make the two marks and skip the TDC part?
Also, people warn against accidentally pulling up the oil pump shaft and dropping it into the oil pan when pulling out the dizzy. How do you avoid this? How do you tell if it is stuck to the dizzy gear? If you see it coming up, isn't it too late?
Thanks in advance!
Thanks in advance!
