Removing knobs (Bezels) from dash
BOSS3024ME
Washington State Vancouver and Oysterville
Hi all<br><br>Just want to remove the wiper switch, ignition switch, and the heater controls so I can paint the dash a little easier.....Is there a trick to getting the knobs off without breaking things???<br><br><br>Do the bezels unscrew or???<br><br><br>Paul
JMurray
Ignition switch, put the key in turn to acc, push a paperclip in the hole, turn cclockwise & pull.<br>The bezel, is kind of notched so you push & turn while holding the backside. <br>Wiper switch has a nut on the back I believe.<br>The two outside heater controls have nuts on the back side.<br>The center heater control, the bezel has a round nut with two notches in it. I use a couple of small screwdrivers to un screw it. <br>Been awhile since I have done that so I am going on memory.<br>Jerry
