removing oil pan
Dachy
San Diego, CA.
so i dropped something in the distributor hole, and i need to drop the pan, question is: do i have to put the frame on jack stands, remove the wheels and let the axle droop to take the oil pan off? or are our rigs tall enough with just 31's to take it off without jacking?
Snafu
Guntersville, AL
I have a 3.5" lift and could just barely squeeze it out of there without jacking it up. If you have less than that I think you will have to jack it up.
theshowson
I have a 2" lift...I jacked the frame to get the wait off the wheels and was able to get my pan out after also dropping the trac bar from the frame and putting the steering hard over one way or the other on my 76... I would think what ever you dropped might be wedged in before it went to the bottom of the pan so you might have to pull the timing cover...Highly recommend a 1 piece non crushable replacement gasket from Summit and if you have to
pull the timing cover, replace any high mileage components...timing set, fuel pump, water pump etc while you're there. Good luck
BG's 68 Bronco
I have no lift... lowered one end of the trac bar and wiggled its way out. I believe i had the jack stands supporting the axle not frame, so suspension would still be under compression.
deluxe
don't worry about removing it
I have a 2.5" suspension lift and dropped the oil pump shaft into the pan. I popped the pan off (only time I used the stock jack) and was able to drop it to the axle. Once down there there was enough space for me to reach in and grab what I lost and then put it back up. It wasn't comfortable but I'm convinced I had enough room to get anything out of there I needed.
sellers69
Durango, Colorado
I got mine off just fine when I had no lift. I think I took the trac bar off to get it back in put that was probally just a lack of patience.
Mikey
I have a 2.5 inch lift and 31 tires and pulled the pan out by dropping it to the axle, then, pulling the oil pump and pickup off, dropping it into the pan then wiggling the pan out. I also dropped the oil pump shaft into the pan and bought a new chrome moly one from Ford Racing.
No jacking or removing anything else was required.
Good luck!
Mikey
