Hello,
I have a 1973 with a stock column and steering gear. Just wondering if anyone has removed the flange that the rag joint bolts to on the upper steering shaft. I have read that you need to use a puller, but I was wondering if you need to take any bolts off also, or if is just held on by tension. I bought the whole lower collapsable steering shaft from Wild Horse, has anyone installed one of these? How does the new u-joint stay on the upper shaft? Does it need to be pressed on, or do you need to make a groove on the shaft for a bolt to slide onto like on the lower shaft to the steering gear? Any help that can be provided is welcomed.
Thanks!
-Eric
Thanks!
-Eric
