Removing Seats - Front & Rear
syndicate1
I have a (simple) question but then again nothing is simple with EB’s.
It’s finally time for reupholstering the original seats in my ‘74 and before I get started, is removing the front and rear seats as simple as just removing the bolts? Are there any issues I should anticipate?
Thanks!
1969miller
Elk Grove
Should be just that simple, depending on your bronco's condition maybe anticipate breaking some of those bolts?
armynavy17
I'm not with the bronco right now, but I believe the original nuts for the seats were welded or captive. Some of them may be stripped or otherwise failed.
jamesroney
Fremont, CA
If you have buckets, There are three special bolts on the front seats that come up thru the hat channel in the floor. They have 5/8 heads, and a shoulder, and the threads point up. There will be a flange nut on the top. If you still have yours...don't lose them. They are stupid expensive, kind of unique, and hard to find. Most are broken off.
