BROWNKO
hi, I have a question about removing the transmission. I followed the basic steps and have now removed the front and rear driveshafts, and the crossmember brace. The transmission is currently raised slightly raised by my jack.
The next step seems to be to disconnect the rods from the transfer case/remove 'the bolt' that holds the shifter to the bracket.
The only 'bolt' i could see is a little 3/8" one. is this the one? I tried many times to remove it - but couldn't. i can't get a a decent angle on it to rotate it. I'm not really sure if this is the right bolt. Any help is appreciated. thanks.
