Repair cracked off ear on OEM fan shroud
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Working on the cooling system on my '67 and found my original fan shroud has a broken off ear at the upper mounting point.
Curious if there's an epoxy or some other mastic that would repair this and stand up to the torque of the mounting bolt. I know the torque is not all that much, but would like to fix this once and be done with it.
sykanr0ng
My 'go-to epoxy' is JB Weld.
Not only high strength but resists heat to 500 °F (constant temperature).
Most epoxies let lose at or near boiling temp.
brian72
Early Bronco Student
i too jb welded one... sanded flat and square and then just drilled a hole for a bolt... worked great
ugly74
Bronco abuser
JB weld may work, but you could go one better and get some Acraglas from Brownells.
That stuff is strong!
sykanr0ng
Use some JB Weld and put some thin aluminum on the radiator side of all the mounting holes, that way they will all be even and reinforced.
DaveLev
Having messed around with my stock shroud so many times, woulda/shoulda just bought a nice aftermarket one.
dholder
Rivet and epoxy a piece of .040 aluminum sheet and then redrill the hole.
