Cracked block repair?
Hoss408
Okay, guys, just replaced the water pump/thermostat in my '73 (and the oil sending unit and extension that I cracked doing so), and have coolant pouring out when I start it. From what I can tell, it appears to be coming out of a crack in the block immediately below the cylinder head on the left (driver's) side. My question is how to repair this? Would JBWeld be okay for a small crack like this? Or am I going to have to actually hook up the mig welder and get to work? (hoping not, new house and don't have 220v power run yet). Any advice would be greatly appreciated!
http://classicbroncos.com/photos/showphoto.php?photo=35018&cat=500
showphoto.php
pcf_mark
Is that crack in the front cover or the front of the block? The front cover is aluminum casting and can get really nasty if the owner did not use antifreeze. No point in welding it if you could get it clean enough and could weld aluminum. Get a used one in a yard?
sykanr0ng
Professional weldors that I have known would use JB Weld for a cracked block.
First off, is it really a crack or a casting flash? At this point I will take it it is a crack. It looks like the timing cover/waterpump boss. But the other end, looks like it runs under the head. Right up to the head mounting hole. At this point the block is not worth fixing.
What problems are you having now? Is it just a line that bothers you? Leak?
patterdale
If it's really a crack the block must be welded or replaced. JB weld is a bandaid on this type of fix and will eventually leave you by the side of the road. Figure out where the water is really coming from and have it fixed correctly. It is hard to imagine you cracked the block replacing the water pump or thermostat. Something does not sound right here.
savage
Bronco Nut
Renton
I would take brake cleaner and clean that area, to see if is leaking their. It might be leaking down from the intake or maybe between the head and block(head gasket).
Action
Intake
Make sure it is not the intake.....That is where they tend to drip.
Jack
strider
Holland
Huh, it actually does look like the cast ear is broken. Almost like the screw was too long and acted like a jack screw to pull it off. If you don't see what I'm seeing, follow the flash as it transitions from the aluminum to the block. You can actually see a mismatch where you would expect the hole depth to end (screw boss). You can also see what looks like corrosion from this crack to the pooled water.
Anyway, I would be ok using jbweld to get it home, but not as more than that very short term fix. That's right where the water comes out of the block, isn't it?
And that head freeze plug looks like it's got a thru hole in it, yes.
