Have a fairly stock unlifted 77 with the heavy rear spring option. The front is a bit soft and a bit low. Frame to axle measurements are pretty close to factory height so the OEM springs are not sagged all that much if any at all.
Have considered the Moog CC814's a a slightly taller stiffer choice as well as some of the 1.5" lift springs the Bronco vendors offer.
Looking for some experienced opinions positive or negative on the different options.
