replacement panel question?
BobbyA
Getting ready to put my new floors in and my drivers side kick panel. Now here are my questions.
1) Did you put the new floor underneath the lip by the door or did you leave it on top?
2) If I was going to replace the door post, couldn't I leave the old one in, replace the kick panel and floor, cut out the post and put the new one in without anything shifting?
Seems like #2 would work but I am sure you guys already tried but would like to know what you think or how it worked.
Bobby
allenfahey
I would do # 1 the way it is from the factory. For your 2nd. question you could do it that way or if it is easier you could cut it all out first then weld in the new. I would measure everthing first and make sure the Bronco is mounted on a frame. Use small self tapping screws to place everything in. Before final welding test fit everything. Make sure the door gaps are good. Then weld away.
You would be amazed at the amount of metal replacement on some repairs at a bodyshop require and it all goes back together fine. Measure, measure, and measure again!
Explorer
Raphine, Virginia
#2 I asked the same question about bracing and decided with top and everything else intact that I wouldn't bother. That corner of dash dropped 5/8". I'd brace between dash and floor support to save the hassle. It's easier to replace kickpanel and post at same time.
