rustbucket1
- Apr 16, 2008
- 2
I orginally thought that I would just be replacing the inner fender and kick panel. But, I got to poking on the door post and rocker and found that they needed to be replace as well. Figured I may as well replace the floor pan too as it has been patched twice by PO. After I took the floor pan out, I found that the 1st support rail was cracked nearly in half next to the body mount. This made the drivers side sag a least an inch. Found other cracks in the rail on the passenger side too. I was wondering why the doors weren't aligned well with the windshield frame when I got the bronco about a month ago. There was a gap between the frame and the door. The gap is even worse now that the bad metal is out. I had the inner fender, kick panel, and door post off before I found the support rail was broke. There was so must rust and dirt under all the patches on the floor pan and kick panel that I don't think the orginal measurement were in spec.
Can anyone provide me with the proper measurements. All the measurement I took just don't seem like they will fix the problem with the Windshield frame lining up right. I don't know what replacement piece to attach first or how to get the windshield frame to move back and down to get the door to fit properly. Thanks for any help.
