- May 28, 2013
- 1,790
Motor is out of a '77 and has Elelbrock 3721 intake with EGR and water passage across the back. Changing to Edelbrock 2121 non EGR for earlier model.
Is it ok to run this manifold without the water passage across the back?
I read that the best gasket is the Fel-pro 1250-S3 that has the steel core, true?
And is it best to ditch the end gaskets and use RTV?
And proper torque sequence and values are key, any other advice?
