This could be a slippery slope. This is how most frame-off restos happen. Knowing what you have done to it already, or what your current setup is, might help others give you some ideas.
Will
$10,000 later...
Obviously, there is a LOT that can be done to a Bronco and almost any excuse can end up being costly. I haven't done a lot of under-the-hood updates to the truck other than the following:
1. New Edelbrock 1403 carb w/ Electric Choke
2. Replaced driver side header gasket
3. All new spark plugs (Motorcraft)
4. Ford starter solenoid
4. Replaced body mounts, c-bushing, coils, and shocks (suspension)
Future Plans:
1. Replace the other header gasket & new bolts
2. New spark wires
3. LED lights
4. Install cold air intake tube
My Bronco is a street vehicle; it won't be used for much off-roading. I just want to make sure that it is in solid condition and it will get me Point A to B and then back again.
