Replacing a lot of the body on my 75. New A/B driver pilar, A passenger pilar, both rockers, kick panels and entire floor.
Purchased the pre-welded floor assembly from Dennis Carpenter.
Starting to screw stuff back together. Have the kick panels welded in. The floor is sitting on its body mounts (nuts not installed). We hung the door to see how far we are off. The door slags a good 2 inches.
I know you can shim body mounts to set the door gaps, but the floor is only attached to the kick panels with a couple of zip screws.
What methodology should we use to insure our door opens are correct before we weld? We have ratchet straps to raise the front and a picker to raise the rear. Posted photos in reply below.
We have the kicker panel and the inner rockers bottom slots lined up and zip screwed together. I assume the inner rockers supplys most of the rigidity to keep the front and back from pigeon toeing in. We would like to have the door openings very close to correct before we weld. Looking for advice on how to achieve that.
This is our first time and we are learning as we go.
