RyanOwens
I am trying to replace my headlight switch on my 1972 bronco.
The headlights worked but the dimmer for the internal cluster lights was not working.
I removed the switch and I am having trouble finding an exact replacement.
I can fine other switched at the parts store that look exactly the same, but they are all missing the 1/2 "spacer" that is welded onto the switch that came out of my bronco.
This "spacer" seems to be what keeps the switch the proper distance from the dash when mounted.
Can I get a switch with this spacer already on it? Or do I need to remove the spacer and install it on a new switch?
If so how do I remove and reinstall it? It seems to be welded to the front of the switch.
Ryan
Ryan
