dprio34
I am dropping in an aftermarket HEI Distributor (with coil mounted on top wheel well so I don't have to cut hood brace) and Re-wiring my Ignition Switch Pigtail at the same time due to it being mangled by PO.
All guidance I have seen says, get rid of the resistor wire when running HEI. I guess this means wires, not wire? Both Pink #016 at Ignition Switch and Brown #214/262 at Starter Relay? Can anyone confirm?
Also, Can I wire a "home-run" from Green-red #904 at the Ignition Switch to the coil on the Wheel well, or will this cause loss of any systems, like brake lights, electric fuel pump, etc?
Thanks to all!!
Thanks to all!!
