Restoring Stock Steel Wheels
Broncitis
MEB Founder
Sandblast to remove all old paint, prime with etching primer, then paint with PPG Wimbledon White or Argent Silver.
That's what we do on our restorations.
These factory option 16" are the latest ones we've done. On these, we added a flattening agent to the paint to knock down some of the high gloss for somewhere between a satin and gloss sheen. I think they look really great with that finish since sometimes parts that are too glossy look over restored, or just not quite right IMO.
mp
Austin, TX
I just had my 16's blasted and powdercoated. Only issue is powdercoat does not like to get into the tight crevices and "spiderwebs" in those areas. I think it has to do with the electron flow. Still look good when mounted, but beware.
Bronco Junkie
So Cal Broncos
I just lightly sanded mine and sprayed with OSH spray paint! I am running hubcaps though.
landshark99
Montrose, Colorado
its hard to see unless you light it up directly in the cracks as i did. iam using this wheel as a spare and it eventually will be covered with a tire cover.. plus hopeing people will be blinded by my paint job so they wont see anything else ;)
Scoop
Have Bronco, Will Travel
Cuchara, CO
The original paint on mine were in good shape so I just sanded and repainted them. I am sure blasting and removing the paint would have been better, but they turned out pretty well.
BoureeOne
Madisonville, La
I will be using the stock wheels I got out of the Pull a Part. I will also be running hub caps. All will get sand blasted, but here is the question. Removing hub caps from the rims can be hard on the rims paint. But it is also hard to justify the cost of having them powder coated when you will only see the outer inch or so of the rim. Any suggestions? I am thinking I will paint them myself with something relatively easy and cheap, and just tounch them up as needed. I have also come up with a little plan for doing a brushed nickel look on parts of the hub caps that I think will really look good.
Scott
BeardedBlues
Sounds like I need to make a trip to the BR Pull-A-Part. The one up here was..... Well, all pulled apart.....
mp
Austin, TX
Just the way it is with powdercoat. Mine look identical and figure no one will see the cobwebs once the rims are mounted and on the truck.
brianz426
Great job on your wheels. Did you use a rattle can? I want to repaint a set of wheels and I'd like to do it myself. Has anyone spray canned their wheels, and if so which brand and color is closest to wimbledon white?
Scoop
Cuchara, CO
Yes, I rattle-canned them. Duplicolor Wimbledon White.
muskrat
Drew, they look great. Love the old bias ply tires on them also.
