Gwunited2
- Apr 7, 2015
- 71
Hello,
I'm replacing the gasket on the rear servo cover of my 1974 C4. Attached is a picture of what the gasket looked like upon removing the cover. You can see that it is angled. The lip on the transmission where you bolt the cover to is angled as well (matches angle of oring/gasket).
Everything I've read and even the parts guy at my transmission parts shop says that you use a square cut oring as a replacement. The question I have is, have any of you all experienced this and used a square cut oring in what looks like should be a triangular seal? Does the gasket conform to the space and form into a triangular type seal? Any help would be appreciated. Thanks in advance.
Massey
Massey
