Reworking dash using a dash overlay
JWMcCrary
Gathering pieces to rework my dash in the spring. I bought the dash overlay from WH on black Friday to save a few bucks, have it tucked away for now.
Who has done the overlay, how does it attach ? do you get it in place and weld?
Any tips on cutting holes and not screwing it up, other than just taking your time? I cut the center out of mine about 15 years ago and it has a piece of aluminum which will be discarded, leaving the area between the steering wheel an glove box open, so it won't be overlaying anything there. Tired of the look and it needs painting so giving it a refresh. Planning to remove the heater as well, it hasn't been used in years.
Old pic from 2005
sanndmann3
I bought the whole dash rather than overlay so no help there but maybe I can help with holes... depending on size you are looking to drill.
I used an adjustable hole saw with carbide tips that I bought off ebay. less than $20
Used a drill press and went REAL SLOW with lots of cutting oil. Did 5" holes 1st, then the smaller ones. Turned out really nice...
JSBX
Dash
I have one of my Broncos at the body shop having a frame off paint job. I have my dash on my welding table and plan on cutting out the center section and installing an overlay that I won at OCBR a couple years ago. I am going to weld it in. It is going to have a custom layout with speakers on each end no glove box, ash tray or instrument cluster. Going with auto meter gauges, tach and GPS speedometer. I am going to mark all the holes and take it to a local guy that has a CNC and let him cut the holes. That should be a little cleaner then drilling. Sanndmann that looks really good.
Cecjap
heres mine, reworked
takes some effort but it does pay off
JWMcCrary
JWMcCrary
Other than cutting the hole for the glove box, will be reusing my tuffy in stock location, the biggest hole will be 3 3/8, that's the size of speedo and tac. With the Holley EFi I don't need some of the gauges but I have them and it just makes me feel better to also have an analog gauge too, and there's room for it.
I have a drill press, figured I would test run on some scrap and then should be OK.
Never used an overlay but it seems if you cut out the center of the original dash from the steering column opening to the drivers side and then the center from the steering column to the glove box opening, leaving a little meat around the main frame and the steering column hole, weld the overlay in place from the backside it should be good and then you wouldn't have double layers to worry about with any of the mounting. Does that sound like a good plan?
Ol'Blue
I did the overlay a couple of years ago and it worked out great. The fit was perfect and you can hardly tell its an overlay.
I removed the old dash and cut out everything except for the area around the column to leave some support. I trimmed the upper section of the overlay off (see pics) to reduce the amount that it stuck out as I have limited space between my dash pad and roll bar and the dash pad covered up the joint where the overlay and existing dash came together. I moved the glove box to the left so I had to weld on some angle to fasten the glove box to. Ya the holes can be tricky, but placing a piece of wood behind the sheet metal seamed to help guide the whole saw and keep it form wobbling. I practiced on the waste pieces from the old dash first. Cutting the notch for the ignition switch hole was a little tricky, but using a Dremel worked okay.
I used sheet metal screws across the top under the dash pad to secure the overlay to the existing dash, then used the two existing bolts that secure the dash to the body to also attach the overlay.
Good luck!
Ol'Blue
This is pretty much what I did for cutting the old dash, but you may consider screwing the overlay to the old dash. Depending on what you have in the way, like roll bars etc. it make it easier to get to your wiring, back side of gauges etc.
JWMcCrary
JWMcCrary
Good luck!
This is exactly what I was needing to hear. Your layout is also looks very close to my intentions. So no welding other than the mounting for the glove box? What size are your speedo and tac? I'll take all the info and pics you want to share.
Ol'Blue
Yep just the angle for the glove box. You may be able to use the existing tabs on the original dash but I wanted to move mine left so I could remove it without taking out the roll bar. I think the Gauges are 3 3/8”. Couple more pics of the fit.
JWMcCrary
JWMcCrary
I'm using 3 3/8" speedo and tac as well, this is big help, thanks
JWMcCrary
JWMcCrary
You got it and let us see the progress!
For sure but it will be a while. I'm rebuilding my stroker and switching to a roller block and custom camshaft, want that done and back running before I start jacking with the wiring, eliminate some troubleshooting if any problems. I did a painless harness in 2005 when I did the work on the dash I have now. Since then a lot of things have changed and the wiring needs a major "cleanup". No longer need the fuel pump wiring when it had a carb and the external fan is now triggered by the EFI just to name a couple things. Removing the heater. Going to do a new ididit tilt column when I do the dash. My stock column has been rebuilt twice and had all the shifting guts removed, never been happy with it, just doesn't turn smooth. If all goes well hopefully tackle the wiring in April.
