Tablet touchscreen dash display with ODB2. AI says to use proven Dakota
skrit
Bull City Bronco
Durham
UPDATED with results from AI in my recent post from 10/11/26.
Touchy subject...my build is not going to be original but a modern-ish restomod...my son destroyed my original speedo cluster when he was a kid years ago... so I'm looking at a new solution thats not Dakota digital.
I have a "what was modern before Coyote" Explorer 5.0L reusing ODB2. Was going to mount an Andoid tablet to cover the original speedo cluster hole in the dash and use an ODB Link wired connection and RealDash app for everything and a push to start ignition.... anyone attempt?
Yeller
Rogers County Oklahoma
It’s been a while but has been done, don’t remember the guys handle, was 2019 time frame. I’m sure there have been others but that one stood out
fordguy
The tricky part is going to be making it look presentable. I run a tablet or phone on a mount with an original cluster (have not installed mount yet) Mine is a restomod with explorer EFI. The table would look good in my lower console.
Yeller
I’ve used a tablet watching stuff through OBDII on my tablet, and a WiFi OBDII dongle but it was purely an exercise in what is the ecm seeing compared to my ears and mechanical gauges. Watching timing curves was interesting.
gnsteam
Lincoln NE
Interesting thread. I am looking for a app to load on an android tablet to see my OBDII, for diagnostics. Probably connect via Bluetooth. So I will be following.
ba123
CA
Well, looking at the Atoto deck I posted, it shows they are using an app called "Torque".
73azbronco
I would recommend a tablet that mounts via an arm and suction cup on dash or front window. Why instead full dash mount? Cost, every few years something newer better comes out, an Ipad can go 10 years and you can update to whatever new software exists.
Yeller
Know a guy running one in his CJ7. He uses a kydex case that the tablet snaps into that is Velcro’d to the dash. He’s changed tablets a couple of times and forms a new case from kydex.
ba123
CA
but tell me what you gain from that in a Bronco? I mean unless you want to remove it? If you do, great, but why not built in? It can look better, be fully integrated, easy to swap and prob less expensive. That one I linked above has a ton of features and on sale with Prime Day for $200. Can't beat it. Also with 4G tracking if you want.
ssray
South Central NE
That brings up a point I was wondering abvout with a regular Tablet which is temp rating so I did a quick search. Consumer devices seem to be rated from 32° to 95° normal operating conditions. Storage seems to run -4° to 113°. Samsung mentions operating temperatures up to 113° under heavy gaming or GPS tracking but also says the tab will take steps to limit or even shut down. Articles mentioned possible damage from high temps whereas low temps just caused temporary issues. Something to think about. A couple levels of "toughbooks" are available if you spend some money!
skrit
skrit
Bull City Bronco
Durham
Thanks all for your input so far. I'm going to do this. I used a Bluetooth OBD Blue Driver dongle in the past just for diagnostics but BlueDriver does not have a good "dash" display and bluetooth has lag.
That's why I'm going to use a wired OBSLink EX device connected to tablet via USB-C... basically Forscan. Looking into either Torque Pro or Real Dash apps.
I'll be modifying my dash such that the tablet covers the existing speedo hole via a surface mount case. I'd ike to use the Wild Horses blank dash overlay but shipping basically doubles the price and it would probably arrive damaged from shipping.
I'll be using info from this old thread...
Post in thread 'Tablet for gauges (OBDII)' https://classicbroncos.com/forums/threads/tablet-for-gauges-obdii.293966/post-3183191
ba123
CA
No idea how it is but came across these guys on eBay while looking for interior q-panel ideas.
Here is a dash overlay and free shipping. They have reg aluminum and diamond plate.
https://ebay.io/m/4skaPh
skrit
skrit
Bull City Bronco
Durham
I may end up abandoning my digital tablet dash idea. I asked Claude AI and it said that it would be better to use a proven speedo solution from Dakota Digital for primary functions and only use the OBD2 related info for diagnostics. I've trained the AI on my exact build so it knows what I'm trying to accomplish. I thought that it might be the case but was hoping I could do what Dakota does on the cheap.
I had it overlay my wiring diagram with what is required for the Dakota and gave me a detailed step by step build sheet.
  • Explorer_5.0_Swap_Wiring_Diagram_Dakota_VHX_Overlay.pdf
  • Bronco VHX Install Kit.pdf
Johnnyb
Flagstaff
I love my Dakota Digital VHX. I can put pretty much anything I want on the right-hand LCD, I usually leave it on fuel pressure.
-JB
ba123
CA
That's a great point from Johnny.
You could just get this interface if you have a Dakota Digital dash or use this as reason to get one:
Edit: Missed the post above where you said you have one.
ZOSO
I run an atoto with torque app all the time. Has been my go to. Only thing missing are oil pressure and fuel level.
