Ride Quality
jeremywatco
San Diego, CA
Finally getting the '73 to be more of a reliable daily driver. Seems like the more we drive it the more we find out is needing work.. which is expected.
One thing that is consistent... the ride quality is VERY harsh. Every little bump feels like something is going to snap off. What would be the best starting point to improve things?
Replace the shocks?
Replace the springs?
Our bronco definitely has a lift on it. No clue how much but I figured I could pull the existing shocks and measure them.
Digger556
Pictures may help.
If the shocks and springs have no identification, pitch them and start with something known. Older lifts tend to have really stiff shocks and springs. A good set of coil springs in the 180-200lb/in range and a quality set of Bilstein shocks will do wonders for ride quality.
J
jeremywatco
San Diego, CA
Here's a pic I just took. Tomorrow I can get it outside and get better pictures.
y4mosIK0B45Rge4RVh_8LSxi5fuT7UMe0Qo7-9HqEMmOcAWKM-H3C0rrh1OUnT5sNq793ojZusTepBI0gqJ3LLbv-JOzfmd0Ptdwj0N5zUeK1Kr1QoLCo28_c7hM7UfhgREHgAnflA4dlpEwmcsr9ayfXfvvKpn_OB8AY9H_-s2Vo2tT8DPBGn2-vB1yEEi64a_oKHjSdAFhqmSiUH6lACbNw
SteveL
Huge chevy guy
Hawthorne ca
Red springs might be rancho which ride like a brick. New springs and good single shocks should ease it up a bit.
WILDHORSES
USA
With red coil springs you would think there is some lift on it. They do look like progressive coils. What do the rear spring look like. Do you have an add-a-leaf back there. The shocks look like they have been there a while. You could also remove the extra one at each corner for starters. I would just take each one out for a quick inspection.
Jim
J
jeremywatco
San Diego, CA
I measured from top of axle to frame font and back and it appears to have a 2.5" lift.
I'll get some pictures later today. Rear appears to have 4-5 leaf springs.
Which front shocks would I take out? The on in front or behind of the axle.
Apogee
Tangent, OR
Personally I would remove the forward shocks, but that's because I would want the space for ram-assist steering, and between the tie-rod, drag link and track bar, you already have plenty going on up front.
As for ride quality, my EB came with some halfway decent older JD front springs and sacked out factory rear leaves with overloads. There were dual shocks on all four corners, half of which had been drilled out, so they were just there for "show". The bad part of the show was the ride quality, which was abysmal. Between the overly stiff rear springs punching me in the kidneys and half of the shocks being seized since they no longer had anything to lubricate the seals, it wasn't much fun to drive for short distances, let along longer ones.
I removed all of the shocks, replaced the springs with CAGE (Betts?) and some CAGE shocks. I went long-arms at the same time and it transformed the ride quality completely. Other than the additional sway/body roll, it made everything better and 300 mile drives were no longer painstaking trips through hell and back. Any good quality springs and shocks available through most of the modern EB vendors should be a huge step up from those Rancho F150 springs IMO and old Monroe (?) shocks.
Local Boy
Mililani, Hawaii
Those (red) springs look like the ones I ran in the 80's. They were (I found out later) truck springs...Very, very stiff, rode terrible...
The diameter of those springs are huge compared to the ones that are rated for our rigs...
Try and measure the diameter and compare to the ones made for ours.... Chances are you'll see a big difference...
Good Luck!
Aloha
Lawndart
When I bought mine, I drove it from PA to KS. It would knock your fillings out.
It had a lift and blue springs - I am guessing K-bar-S.
Installed all new suspension, stock height. Wow, what a difference!
Edit - those red springs look to have been painted. Overspray all around.
jckkys
I also had the early '80s Rancho lift kit for for a few days (all I could take). I'm sure they're embarrassed they did that. These were twice as stiff as F150 or '78-'79 Bronco front coils. In fact the OE '78 Bronco/F150 coils ride quite well. They match the 49,000lb. rear leafs. I've had good service out of Rancho 5000 shocks, and wouldn't hesitate to use them again, if my daughter didn't work for Fox Shocks. The '77 rides as well as my wife's Escape. I think the early '80s Rancho coils were something like 700lb/inch rating, maybe more. The stock 49,000 lb. GVW rear leafs were about 290 lb./in. and stock '78 Bronco front coils are about the same. With good shocks this combination rides and handles well. I do have a '76-'77 front sway bar and a Hellwig rear bar, that help the handling.
rguest3
Rear Springs look like the Original springs with an Add-A-Leaf and Block. NO WONDER you have a stiff ride!
If it were me, I would replace the Front and Rear Springs with a Wild Horses 2 1/2" Suspension Lift Kit with the Bilstein Option. Night and Day difference from what you have now. You will enjoy driving your Bronco.
bigmuddy
Marthasville Missouri
IT would appear that the front coil springs have been painted red, as the coil bucket and the retainer have red paint on them that matches the coils. I'm guessing they are a truck coil. As rquet3 said, if you can afford, buy a new WH system and you couldn't be happier.
