Rocker Arm Stud Nut Install
airbur
Castle Pines, CO
Installing my newly rebuilt OEM 302 heads tonight. Reading the Ford maintenance manual, it shows only a torque value for the rocker arm stud nuts (17-23lbs). From what I have read, the proper way to adjust rockers is to tighten just until the pushrod takes a little effort to turn, then about 1/2 turn more. Which process do I use? I'm tending toward the Ford process as it's all OEM parts...heads, pushrods, lifters, rocker arms etc.
When I removed them, I measured the length of the threads on each stud above the nut and every one was 1/2".
Thanks.
rynos72
I re torqued mine at 18 ft lb, got about 300 miles and they are still quiet, i felt better about going with OEM standards.
broncnaz
Most factory 302's are non adjustable just torque and go. Push in positive stop studs with rail rockers arms are not adjustable
Desert Dweller
Central WA
Do you see the shoulder on the rocker stud? That means that you have non-adjustable rockers. So, torqueing them as the manual says is correct. :cool:
TwoDalesDad
On a small block ford engine tighten like this...make sure the pushrod is seated..then with your thumb and forefinger roll it back..and forth..tighten..just a little more..where she's snug....NoMORE...NOLESS....when you hold the skinny pedal on the floor....for any real legnth of time....the press in studs will lift out of the hole...which will mean a loss of power....and God forbid...the pushrod will get jammed through a piston....NO Way....JB WELD...will not help.
airbur
airbur
Castle Pines, CO
Yep...that is how I was shown (Bad Ass Engines video), but these are OEM and non adjustable so I wasn't sure. Sounds like the torque-and-go process as Ford prescribes is best.
Got the rockers on and the intake set.....
Thanks!
RG75Bronco
Jacksonville
While we are on the topic I have a question. When I had my 1975, 302 rebuilt I installed GT40P heads and used the stock push rods. Adjustable or non-adjustable? I adjusted the rockers to OEM specs. Thanks for input.
bmc69
Never, ever is that the correct procedure with the non-adjustable rocker setup. All you will do then is leave them loose to quickly back off...wherupon bad things can happen.;)
broncnaz
non adjustable there as well. the only factory heads that came with adjustable valve train were pre 1970 might even be 69 heads and even a lot of those were not adjustable
bluesbish
Upstate New York
How is this even possible? I know a lot about engines and I can't really think of any way the push rod can go through the top of the piston.
airbur
airbur
Castle Pines, CO
ROFL....I was thinking the same thing when I read that....but figured he new something I didn't:) Anything is possible!
