Rocker switches
strider
Holland
I laid out my gauge panel in CAD then had it laser cut out of 14ga stainless. I think that's the way to go. A lot of laser shops do government work cheap. This was $10 cash out the door and they completed it the afternoon I sent the file. If you've got a hand sketch of what you want for a panel I could create the dxf file for you. My gauges are just set in place in the pic but you'll get the idea.
https://www.dropbox.com/s/a1g63lpqmsisv7a/20150624_210302.jpg?dl=0
C
crawler73
That looks awesome! What type of auto meter gauges are those. Off the top of your head what did you pay for the 7 gauges?
strider
Holland
Mine are actually Equus gauges from Summit Racing. The trip gauges (oil pressure, temp, and volts) were $49, the tach was $79, speedo was $79, fuel level was $19, Tranny temp was $49. Those are from memory, even though it wasn't long ago. Autozone does carry most of these too.
And thank you. I am happy with how they're turning out.
AZ73
Nice. I've been laying my dash out but I already purchased the hole saws to cut it. Note if you're using Autometer gauges: All the holes are the same size as the gauge. So a 2 5/8 gauge uses a 2 5/8 hole EXCEPT the Tach/Speedos. The 5 inch takes a 4 5/8 hole. Will be using Contura XlV's. My dash looks busy so I might change it still.
  • Dash 2.compressed.pdf
matt w
I would like the same thing but with the ability to mount the whole system under the dash!
mini73
Thanks for the info about the gauges. I will be starting to get my autometer gauges soon. I
I'm planning on doing my dash similar to yours. Just going to buy all my first before pulling out my dash to install them. Thinking I will try and do it when I throw in the 351W. Are you going to be using the 5" gauge for your tach and speedo?
