Roll bar interference
jerrybromley
Do all the front portion of roll bar kits interfere with the glove box and emergency brake? I will be adding a roll bar to my rebuilt bronco and I keep reading about cutting the glove box door and relocating the emergency brake pedal. I am trying to modify as little as possible.
No Hay
I had to get a Tuffy glove box door for mine.
Don't move the E Brake till you're done! My stops 1/8" from the down tube so it didn't need to be moved.
jerrybromley
jerrybromley
Thanks lot the info ! At least I know it can be done without modification
BroncoChicken
A guy in our local club built the cage that Tom’s “used as inspiration” for their plate design. It’s a fantastic idea. The Krawlers Edge cage will support the windshield without a top but is worthless as structural support for the front in the event of a rollover.
There are several options to mod the e-brake and the glove box. E-brake can be angled in a little, arm can be cut and welded on sideways, or it may fit as is. Glove box can be replaced with Tuffy, sliding hinges, or the mod that makes it swing open instead of flipping down.
Rustytruck
the smitty built add on bars block the glove box and you can squeeze in the parking brake if you can twist your toes. it works. just remember to open your windwings on your doors before closing the door. cant open them with the door closed.
SteveL
Huge chevy guy
Hawthorne ca
I'm with bronco chicken about the krawlers edge cage. Them front bars are worthless for protection. For the necessary mods the e-brake is minimal. Just refill the hole in the bottom of the dash and flex it over an inch or so. Theres also an old mod for the glove box door where you just lengthen the hinge pins. Everything else remains stock. When you open the glove box it let's you slide the door to the left so it fully opens.
Skinnyr1
I went with the Tom's plate cage posted above, but eliminated the horizontal dash bar.
For a street or mild trail rig, I don't see anything wrong with the krawlers edge cage. It is no different than a Jeep Wrangler TJ cage straight from the factory. Modern factory vehicles.
Its all a compromise somewhere.
HigginsHorse
I second or third or whatever the Tom's plate cage. I installed mine a month or so ago and am very happy with it.
73azbronco
Krawlers edge I think lacks any roll cage protection, albiet some extra beef up front but last thing I want protecting me from 4000lbs of metal is a window frame. Next best option would be the version from BC I think, with only one downtube over transfer case, that at least supports roof.
My full cage does restrict ebrake, but still usable in original spot. Had to go tuffy box, but there is a mod to adjust hing pins and use stock box.
SteveL
Huge chevy guy
Hawthorne ca
Bc roll tested their cage before making em available to the public. The video was up on their site. Also the downbar up front was removed for street driving. Cant remember if they tested it both ways.
Timstrk
I used TBP plates and built a cage for my half-cab. Everything clears but you sacrifice the vent windows. They won't open far after the plates are installed. I'm good with that trade but I've locked my key in the Bronco more than any vehicle I've ever owned and that was my way back in.
thiswildbronco
Regarding TBP plate setup, I have a couple questions. And it sounds like a few of you have direct experience with it.
1. Is the bar across the dash absolutely necessary? Skinnyr1 sounds like it was deleted in their case. My rig will see mild off-road use. No severe rock crawling for me. I’m hoping to keep the cab feeling stock-ish.
2. Will the plates prevent installation of speakers in the kick panels? Sure looks like it would. I also plan on have the doors removable and don’t want to mount speaker there for that reason.
Thanks y’all!!
Skinnyr1
Ill take some pictures of mine and post it. I initially was going to run the bar low with no dash pad. But the way the kit comes, I would have to splice the bars with an additional bend to lower it a couple inches. Not worth it, since I didn't like the look across the dash anyway. That would have been a lot of work and I don't have access to a tube bender readily.
So I instead am running the dash pad and 90'd the bars to the plates with a miter cut. I think it looks great, and for what I need it to be, will be plenty strong.
Kick panel speakers would be a challenge i'm sure. Instead of those, I am running the d-52 dash speaker and a wet sounds sound bar. I also will have 2 8" subs in a center console that I custom made.
thiswildbronco
Thanks! That would be awesome, and much appreciated!!!
mattyq17
I agree with 68Ford, behind the dash is the way to go. I like his idea of moving the dash out when you go behind it to give you more room. My next one will be that way but this is what we came up with on this one. The ebrake is easy to move over, and I will figure out the glove box when I get one, lol, but for storage I will have a center console and we made a box that goes under the passenger seat.
