buckintone
put as close to a 45 degree gusset rom the frame to the cage, put a flat 1/4" polyurethane bushing, possessing the same hardness derometer as the polyurethane body mounts you're (probably, or should be)using now, sandwiching the floor pan between the gusset and the cage mount. Make your gusset frame mount 3 sided over the top, outside and bottom of frame rail (3)attachment points to ward off a shear failure from occurring in the event of a roll over. The added benefit of this is chassis rigidity, which is highly desirable in any vehicle. I even ran a bar over and through my engine compartment to tie my shock hoops together for added rigidity. It will make your ride feel better than you ever imagined it could. suspension dictates ride comfort , if you're looking for comfort loosy goosy style, get a cadillac or isolate ur seat mounts and your steering column with some kind of soft rubber bushing. If ur worried about a hinged bushing like most of the pictures on this thread, you better start with your body mounts because there's no hinges on them.....%)yet
