Roll Cage Dome Light Ideas
72bronco
I'd like to install a dome light in my EB and I'd like to get some ideas on what others have done. My preference would be to mount it on the roll cage. I'm even thinking of installing pins in the door posts so it comes on automatically when the door opens. Any ideas would be great and pics would be even better if someone has done something cool. Plus, what vendors would have the accessories I'm looking for?
toddz69
[quote author=72bronco link=board=5;threadid=11868;start=0#87345 date=1038718609]<br>I'd like to install a dome light in my EB and I'd like to get some ideas on what others have done. My preference would be to mount it on the roll cage. I'm even thinking of installing pins in the door posts so it comes on automatically when the door opens. Any ideas would be great and pics would be even better if someone has done something cool. Plus, what vendors would have the accessories I'm looking for? <br>[/quote]<br><br>Tony:<br><br>Here's an idea that's worked well on mine:<br><br>http://www.azbronco.org/tech07.htm<br><br>Todd Z.
kuch68
Waterford, MI
[quote author=72bronco link=board=5;threadid=11868;start=0#87345 date=1038718609]<br>I'd like to install a dome light in my EB and I'd like to get some ideas on what others have done. My preference would be to mount it on the roll cage. I'm even thinking of installing pins in the door posts so it comes on automatically when the door opens. Any ideas would be great and pics would be even better if someone has done something cool. Plus, what vendors would have the accessories I'm looking for? <br>[/quote]<br><br>I don't have any pictures of mine, but what I did for the front seat lighting was replaced the original rear view mirror with a rear view mirror from a late 80's chrysler lebaron convertible. It had two lights on the underside of the mirror, and it shines pretty bright. I currently have it hooked up to a throw switch, but will probably hook it up to the doors eventually.<br><br><br>Josh<br>75 Bronco<br>http://www.geocities.com/broncokuch/
Hnrys69
I am going to eventualy buy an overhead TV setup with dome lights built into it. Before I do that I think just going to the junk yard will show you many options to doing this. Just search the cars for dome lights and pop one out you like. For the wires, if you have padding on your rollbar you can hide wires super easy. If not drill a hole and run the wires. Then the outlet where you want in the same tube of the rollbar and drill a hole there. Then feed the wires until you can see them then grab them with plyers or a small screwdriver if possible. This is how we always have mounted our tower speakers on wakeboard boat towers...
BwoncoHowie
C-4 Wizard
I haven't decided yet on how&what to do about an overhead dome yet. I did however discover something that works well for the foot well. I used under dash dome lights from an early mustang/cougar. Its fastened under the dash with 1 sheet metal screw and plugged right into the existing harness (red/blue tracer) wire running under the glove box toward the passenger side door.
