I am installing Recaro style racing seats in my 75 Bronco. I was planning on bolting the slides directly to the floor for more head room. Here is the question...
only 1 of the existing holes is visible from under the Bronco and the other 3 seem to be drilled into thicker metal and threaded. Will it be easier to make flat brackets that match the existing holes and attach the brackets to the new slides or drill new holes right into the floor and attach the slides directly.
Thank you!!
Thank you!!
