When I got mine 10 years ago, it had so much dust in the tank, that I could only go 2 miles before it clogged a filter. I like the marine filter idea, but you could also go with one of the large size fuel filters, and then add a see through filter near the carb, so you can check on your fuel flow. Then add a bottle of fuel injector cleaner, and then fill the tank to the top. The additives that create gunk should dissolve, but it will be much better if it has a full tank to disolve them. It may run crappy for a tank or two until you go through it.
Tom
