- Jun 5, 2007
- 1,762
While back I posted some picks of this. Drove 4 hrs and was dark when I bought it. Next morning posted some pictures because it looked a lot rougher in the light. Folks said it was probably usable.
Well I tore it down to take and get blasted. Before I pay someone to blast it, I just wanted some opinions on it now that I have some better pictures. I was able to extract every bolt and broken bolt, so I’m good there. My main concern is where the “c” bushings mate to the axle for the radius arms.
Do the “c” bushings squish enough to over come the metal that has rusted away? And if not has anyone ever built it up with a welder and ground it back into shape? Or would that most likely put to much heat into it? Or just be impossible to get the shape correct?
Also inner seals are in there and there was gear oil still in it. So I’m thinking the center section is still good, sealable, and rebuildable.
I’m not aposed to cutting those “c” bushings mounts off and doing some sort of custom link set up. But that’s just a lot more time and money. And maybe someone might see something that renders this just scrap before I keep moving forward. I have a great 79 bronco axle here for use of the knuckles.
Here are some pictures of the pile of rust that came out of this little axle. And my areas of concern.
