I have been having a running issue that has been getting worse and now getting to point my truck has become undriveable.
What I have mustang efi , Ron francis/rjm harness and a centech body harness Vintage aire magnum.
it started to miss and cut out a few months ago when I had ac on and fan on high and was putting engine under a heavy load. I could keep it from cutting out by turning the fan down Or I was to let up on accelerator the truck would run fine. Yesterday I took truck out and drove it about 10 miles it started doing it again this time without any fan on and light throttle.
I had reset the ecm previous to taking it out to see if it would solve the problem. after taking it out now only codes I get is 15 koeo. Which is kam failure from resetting ecm I believe.
I have the feeling it is a power or ground issue to ecm I checked the wiring for rjm harness ground on back of engine. The dedicated ground for the air.
It is almost like the ecm resets I am going to take it to work tomorrow and figure out if there are any other hints. I almost believe the check engine light flashes when it does miss/cutout.
