Eoth
- Mar 10, 2004
- 1,692
Ok... Some moron managed to use a female end of a hydraulic hose on my saginaw high pressure port coming out of the pump (should be male). Since I do not have the correct hose to take to the part store does anyone know if the stock Ford high pressure hose will work for both Saginaw GM upgrade and stock? The only other item to add is that the high pressure port has a "adjustable right angle block" mounted on it. (I hope that make sense)
Thanks!!
Thanks!!
