- Apr 19, 2013
- 344
I just bought this vacuum sand blaster,http://www.amazon.com/gp/product/B00IG73PSI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1, hopefully it is good enough to do the underside of my body and the frame/axles/transfer case. My question is which media should I use on the Bronco? I am not sure if I should use the Black Beauty stuff or walnut shells. Also coarse, medium, or fine? I have a few spots of surface rust in the bed around the wheel wells, nothing bad but I can't sand it properly by hand. The underside of the body looks to be coated with years of grease and dirt but I don't see anything other than some light surface rust. I want to make sure I can get through the dirt/grease without hurting the body panels. I am not blasting the entire body since the rust in the panels has been fixed/replaced, just some spots I can't reach with my hand sander. I am hoping this vacuum blaster can handle this, I really don't want to send it out. Thanks for any help!
