Cooter_76
- May 18, 2004
- 863
I have an Edelbrock 1405 Carb that came on my Bronco when I bought it back in '04. I've been fiddling with it over the years and have never been able to get it to run well off road (I know, common issue with these carbs.) I installed the spring-loaded needle & seat, blocked the crossover channel and set the floats per some tech article I found a few years ago.
The one thing I haven't done (aside from tossing this carb in favor of a Q-Jet or EFI) is installing a pressure regulator. I did buy one of the simple dial-type regulators a few years ago, but it started leaking the moment I installed it, so I scrapped it.
I'd like to install a regulator/gauge combo and like the looks of plack's setup here.
Questions:
- Can anyone recommend an affordable regulator/gauge setup?
- Will a hard line from the carb to the gauge & regulator transfer too much eat to the fuel? I have a 1" phenolic spacer installed to help prevent hot-start issues.
Questions:
