Seat Upholstery
Green-Machine
I was wondering if anyone has installed TMI front seat upholstery. I have the houndstooth from Wildhorse. (I am using new foam.)
It seems like there is not enough material to stretch over the seat. I am having to pull super hard and cant even get it close.
I watched a CJPony video on upholstering early mustang seats (there foam was a little different) but they just pulled it by hand and had plenty of material.
I believe my seats are from a 1975 bronco, they have the later plastic covers.
Slowleak
Georgia
Do you have the right foam? TMI makes a sport version which has thicker bolsters. Maybe you have standard covers and sport foam....
https://www.tmiproducts.com/sport-r-ll-molded-foam-pad-set-1968-69-mustang.html/
nickgp
Try wrapping your foam w thin trash bags. It helps let the cover slide over the foam.
G
Green-Machine
Good idea, I was trying to think of a way to help it slide better.
The foam in the link is what I have, but ill try to get some pictures of mine.
73azbronco
Pro's do it easy cause they are beyond strong in arms and hands.
For us mortals, Heat, as with all things.
Try sun first, but it's winter. Then a heat gun but be pretty careful. You could try shrinking the foam in a space saver bag.
Or do what I do now and let a pro worry about it, they got wicked strong arms and hands.
75Denver
I've done three sets now and after discovering the heat trick, I won't ever try it another way. Use either a heat gun or borrow your wife's blow dryer. I typically turn the covers inside out, heat up, line up the top edges and slide them over the seat cushions. You have to move fast but it'll save you a lot of cussing and ripped stitches. Also, don't forget to hog ring the lower seat cushions to the frame with the listing wire FIRST! Good luck!
hyghlndr
Hockessin, Delaware
Put foam in trash bags, makes the vinyl slide easily. Also use your body weight and effort to move it where in needs to go, if you aren't sweating when done they aren't done as good as they could have been, joking but pretty accurate.
Slowleak
Georgia
Cable ties help if you a pulling wires down. Kinda like using a little ratchet strap on them....
G
Green-Machine
I heated hot to the touch. I was able to get the sides on but the bottom does not want to go. I’ll give it another try.
G
Green-Machine
I feel like I’m going to rip out the stitches on the bottom. I already ripped a little corner.
martinphoto
Go to walmart and buy an upholstery steam cleaner. It will get it as hot as a heat gun but less chance of doing damage. It will also help with getting wrinkles and creases out when you are done. If you are brave enough you can get something to put on a drill that will help cut down and shape the foam you have. I have done it but upholstery is my side gig and I am still learning. There are vids on yt that show how to shape foam. Or just take the bottoms to a pro and let them do it.
