Incognito
I Am considering starting my next Bronco project.
I Am looking to see what anyone is willing to trade.
Pics in my gallery, specs below. All it needs are disc brakes and new 3 1/2" rear leafs.
I would take a 2005 or newer 350z convertible with nav or similar valued vehicle in trade. Honda S2000, Cadillac CTS.
Just testing the waters to see if something interesting comes along.
1967 Specs
Engine 289ci original
Carb Holly 2 bbl
Headers WH Shorty
Alternator GM 1 wire internal regulated
Starter Stock
Radiator Ron Davis Aluminum with aluminum shroud, zinc plug and cap.
Mufflers Magnaflow
Drivetrain
Trans JD 3 spd on floor
t-case Dana 20
Gearing 4.11 original
Front end Dana 44
Lockers none
rear end Ford 9"
Lockers none
Brakes Front Drum
Brakes rear Drum
T-Case shift T
Clutch
brakes Power Booster WH
Suspension 3 1/2 " lift
Springs Duff 107V-3 1/2" variable rate coils
Shocks Rancho 5000
Lift-Susp 3 1/2"
Lift-body none
traction bar rear None
front Radius arms Stock
Rear leafs stock with lift block
Bushings New Duff Poly
Steering Stone Crusher drag link & tie rod-Single stabilizer
Box Stock
Wheel Grant model#
shaft Stock
Column Stock auto
Fuel Tank 23 Gal BC
Pump Stock
Bumper
front Protofab Rock Solid winch with push bar
rear Protofab tube-stock swing out spare tire carrier
seats Procar Rallye Black
Seat belts 3 pt shoulder
dash Terra Comp, Auto Meter gauges, 12volt guy switch panel, bronco column cover
Hella map light
Rear seat Stock rear recovered.
Horn Hella dual air horn
stereo JVC KD APD58
amp Kenwood powered sub under pass seat.
speakers Pioneer 5 way 6 x 9, pioneer 3 way 6 1/2"
Console Tuffy locking w stereo
Wiring Centech harness
Paint color Gunmetal Grey Acryllic
Blackout color Duplicolor black
liner brand Herculiner
undercoat
hood Stock-
top Bestop with tinted windows
Onboard Air ViAir 450c w/ 2.5 gallon tank
Lights PIAA 520 ATP and PIAA 520 driving, PIAA 1400 rear work lights
Winch
tires New BFG 33 x 12.5 x 15 At/KO
wheels American eagle 15x10 Model 186 5 x 4.5 3 1/2" backspace?
hubs Stock
Roll cage Smittybuilt with front cage
flares Wildhorses Gorilla Warflares black with black hardware
Rocker guards Hanson rocker guards
E Brake original
Shift Duff stainless shift knobs
Heater Removed
1967 Specs
Carb Holly 2 bbl
Headers WH Shorty
Starter Stock
Mufflers Magnaflow
Drivetrain
t-case Dana 20
Front end Dana 44
Lockers none
rear end Ford 9"
Lockers none
Brakes Front Drum
Brakes rear Drum
T-Case shift T
Clutch
Shocks Rancho 5000
Lift-Susp 3 1/2"
Lift-body none
Box Stock
Wheel Grant model#
shaft Stock
Column Stock auto
Fuel Tank 23 Gal BC
Pump Stock
Bumper
Hella map light
stereo JVC KD APD58
undercoat
hood Stock-
Winch
hubs Stock
E Brake original
Heater Removed
