SEFI starting/running rich problems
Silverhorse
Pensacola
Ok, Truck will start and run good until it gets warmed up and then I have to press the pedal down to start it? Appartently it's running rich, but why? I swapped computers and got the same result. KOEO 15 and 85. KOER 11. Thanks for any help!
70EB
Gig Harbor
I think you might have a computer issue.
85 KOEO code is OK
15 KOEO code is another issue - EEC permanent Read Only Memory (ROM) test failed. Looks like a computer issue.
11 KOER code is a system pass code for that scan.
Does your computer have any broken pins, dirt in the connector, good grounds?
Silverhorse
Silverhorse
Pensacola
85 KOEO code is OK
Looks good from what I can tell?
jurob
Virginia Beach, Va
did it used to run good when warm?
you have a closed loop issue, but what?
i would start with tapping into your o2 sensor and check your voltage to see if their dead thus dumping fuel. should get a code for bad o2 though.
for poops in giggles try uplugging your egr it its still functional.
